Hello Guest it is November 18, 2026, 11:19:41 AM
Author Topic: Help My XYX Axis travel at 10mm instead of 1mm  (Read 9771 times)
« on: May 25, 2011, 05:10:43 PM »
I'm new to Mach3.  I have a Taig machine with Gecko 540.  My Mach3 read Gcode z1 and Zaxis travel 10 mm instead of 1mm.
It also does the same for X and Y axis.  What have I don't wrong?  I tried to use scale it 0.1 solved problem but when I tried to upload Gcode then the scale is off 1.00 again.
Re: Help My XYX Axis travel at 10mm instead of 1mm
« Reply #1 on: May 25, 2011, 09:55:41 PM »
Is the drive are set to microstep
If you done the calculation for Mach3 for microstep (1:10) and the driver are set to single step (1:1), you'll get that result.
Jeff
« Reply #2 on: May 26, 2011, 12:09:24 AM »
Thank you very much. I got it fixed now.
