Hello Guest it is October 25, 2026, 03:16:22 AM
Author Topic: Motor stall killing me!  (Read 38225 times)
Re: Motor stall killing me!
« Reply #10 on: May 20, 2011, 08:28:23 PM »
yes, constant feed. Yes, I swapped drives and motors and no change. I even tried a 425oz motor, same result. I checked for binding seems smooth. I tightened the belt and loosened the belt. I wish I understood more about the relationship between Velocity and acceleration. I have my "steps per" set at 32000 is that correct?
Joe
« Reply #11 on: May 20, 2011, 08:50:45 PM »
Have you checked the active state of the STEP pulses ?
Russ
« Reply #12 on: May 20, 2011, 09:24:45 PM »
Where do you check these settings?
« Reply #13 on: May 20, 2011, 09:45:23 PM »
Under Config/Ports and Pins/Motor Outputs
Russ
« Reply #14 on: May 21, 2011, 01:39:36 AM »
If the active state doesnt help then swap wires on your breakout board so X is using the Y pins and Y using X.
« Reply #15 on: August 02, 2015, 02:52:54 AM »
I'm having a similar issue. I turned my x axis into a belt drive and now the stepper stalls, which it didn't do when it was in direct-drive mode.
swapping the wires didn't do a thing.  y kept moving on x driver and x stalled.
Have you found a solution?  or a why is this happening?
Offline beefy
  •  138 138
« Reply #16 on: August 02, 2015, 01:33:07 PM »
I had that problem with my crappy Chinese motors - "Smooth" brand LOL. In the beginning I had a Leashine drive. It required a pulse width of 8. The Leadshine drive could run the motor slow but when the speed got up (like in your video) it would just stall and scream (no load).
I changed to Gecko G203V drives which run fine with a pulse width of 2, and can run my rubbish motors up to speed.
Hope there's something in the above can help.
Keith.
« Reply #17 on: August 06, 2015, 09:53:08 AM »
The Xylotex drive is very bad about harmonic resonence. Especially with 20 tpi screws.  I delt with that for years before switching over to a G540.  I finally had to build dampeners for the machine.  When i watched your video, Especially at the end I could hear the motor lock up and whine.
https://www.youtube.com/watch?v=9RoOZs9LrYo
https://www.youtube.com/watch?v=ivDQTeGuduk
https://www.youtube.com/watch?v=8Am69_F93yA
