Hello Guest it is October 24, 2026, 06:47:45 PM
Author Topic: Controlling Mach with Powerpoint? Is this possible?  (Read 70770 times)
andrewm
Re: Controlling Mach with Powerpoint? Is this possible?
« Reply #40 on: May 27, 2011, 01:55:03 PM »
Im not sure how you would do that in VB, Sorry.
« Reply #41 on: May 27, 2011, 01:59:40 PM »
No problem, Thank goodness I don't need that now since I finally got PPT to add the fades in where I need them.
Thanks again.
andrewm
« Reply #42 on: May 27, 2011, 02:11:34 PM »
NP, Glad you got it working ^_^
« Reply #43 on: May 30, 2011, 12:46:26 PM »
Thanks again for all your help!  Here's a video I made of the macro in action.
http://www.youtube.com/watch?v=Kc0pd-WNfqI
« Reply #44 on: May 30, 2011, 06:20:30 PM »
Andrew, I have a question:  Right now, when I run the macro, the machine moves at the start of (before) the first slide. Is there a way to start the Zmovement "after" the first slide? The first slide needs to be shown when Z is still at zero(Const ZStartPoint) then I need it to do the first move before the second slide, then continue as is. How can we edit the macro to do this?  Thanks.
Jon
« Reply #45 on: May 30, 2011, 08:57:53 PM »
Not Andrew but you may want to try it this way.
For s=1 To numSlides
 objPresentation.SlideShowWindow.View.GotoSlide (s) 'show the next slide
  sleep exposureTime
  Code "G1 Z" & ZIncrement + ZIncrement 'lift Z a couple of tads
  While IsMoving()
    sleep 10
  Wend
  Code "G1 Z-" & ZIncrement 'lower Z a tad
  While IsMoving()
    sleep 10
  Wend
NEXT
Just a thought (;-) TP
« Last Edit: May 30, 2011, 08:59:33 PM by BR549 »
« Reply #46 on: May 30, 2011, 10:05:58 PM »
Thanks TP, That did the trick!
« Reply #47 on: June 09, 2011, 04:12:18 PM »
BR549
Why the  Code "G4 P2" was omited in your last reply (#45)? That is no longer necessary?  ???
What is the final version of the macro?
Thanks for sharing, this is really amazing.
  sleep exposureTime
  While IsMoving()
    sleep 10
  Wend
Code "G4 P2"
While IsMoving()
    sleep 10
  Wend
NEXT
« Reply #48 on: June 09, 2011, 11:05:55 PM »
The final configuration is this:
  Code "G4 P2"
  While IsMoving()
    sleep 10
  Wend
  While IsMoving()
    sleep 10
  Wend
The G4 is not really necessary, it just gives a slight delay between the moves. I will know if it needs to be there or not once I start experimenting.
« Reply #49 on: November 10, 2011, 12:42:11 PM »
Hello,
Would be possible edit the macro in order to activate & sync a second axis (..X or Y..) during the time when the screen is black (...machine moves up, pauses, then moves back down)...?
This is for a tilti-action system that I try to implement.
How can I edit the macro to do this?
Any help will be greatfully appreciated.
