Hello Guest it is November 20, 2026, 09:05:09 AM
Author Topic: Simplify Screen button  (Read 28473 times)
Re: Simplify Screen button
« Reply #10 on: November 29, 2006, 11:58:13 AM »
Hi
 I use a large resolution on my home computer (1280 x 1024) and I dont see the simplify button off screen. This is probably due to the standard screen getting updated with newer versions of Mach3. I suspect you may be using ver 1.84 and as such have the older standard screenset.
  Have you tried going to the view tab at the top of the screen and choosing "load screen", it should then open a window (C:\Mach3) where you can choose a screen to load, choose the 1024.set screen and after a few seconds it should load. If the window that pops up doesnt open at C:\Mach3 just browse to that folder and you will see the screenset mentioned above.
B. Ender
« Reply #11 on: November 29, 2006, 04:41:06 PM »
Thankyou, Hood
 Yes I am using 1.84 and your fix worked perfectly for me.
 Thanks again, B. Ender
« Reply #12 on: November 29, 2006, 04:45:25 PM »
Glad your sorted.
