Hello Guest it is October 20, 2026, 05:06:55 PM
Author Topic: Mach offseting my work  (Read 19760 times)
Re: Mach offseting my work
« Reply #10 on: May 07, 2011, 12:01:15 PM »
IF it were the fixture offsets then it still would cut correctly as the offset wouldbe active ALL the time.
I think what you are seeing is the the 0,0 is being set off the tool centerline BUT the cut is being "measured" off the tool radius.
Just a thought(;-) TP
