Hello Guest it is October 20, 2026, 03:09:50 PM
Author Topic: Radius tool compensation  (Read 19635 times)
Re: Radius tool compensation
« Reply #10 on: May 10, 2011, 10:29:02 AM »
The g-code needs to be created with G41/G42 in mind, as you need to use lead-in and lead-out moves. If programmed correctly, then yes, you can use different size tools.
But, you can't just add a G42 to an existing program without other modifications, as it most likely won't work.
« Reply #11 on: May 10, 2011, 10:41:07 AM »
Do you know how I can create a program taking in consideration the G41-42? Do i Have to change the post processing files?
If that is the case it would be a problem since I have no idea how to do it.
thanks
