Hello
Guest
it is
October 20, 2026, 08:47:36 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
4th Axis Rotary Table!!!
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: 4th Axis Rotary Table!!! (Read 26572 times)
Jeff_Birt
1,107
Re: 4th Axis Rotary Table!!!
Reply #10 on:
May 08, 2011, 10:34:52 AM »
They failed 100% of the time.
Wow! Well, I guess at least they were consistant
Logged
Happy machining , Jeff Birt
Check out
www.soigeneris.com
Hal
60
Reply #11 on:
May 08, 2011, 01:52:06 PM »
I would go with the Sherline. There are many sites for tilt tables and right angle mounts.
If you need a larger indexer, look for a used HAAS unit. Maybe pricey, but industrial strength.
Logged
Jugster
120
Reply #12 on:
May 09, 2011, 08:51:58 PM »
Jeff,
Thanks for the additional info. I probable go ahead and order one from you in the next couple of weeks. Just trying to do a clean up in my shop before I start another product.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
