Hello Guest it is April 25, 2024, 12:42:41 PM
Author Topic: Demo Gcode  (Read 206675 times)
  •  9,199 9,199
Re: Demo Gcode
« Reply #30 on: June 23, 2017, 08:00:26 AM »
The Gcode for the excellent hold-down clamps described in the CNC Projects website http://www.cad2gcode.com/cncprojects/id14.html and linked by Jeep534 in post #17 has now been added to the Zip file.
Re: Demo Gcode
« Reply #31 on: February 04, 2018, 02:49:55 PM »
why does everything in mach3 seem to be so small...... I DL'ed tweakies scorpion .TAP and it loaded so small?? It does this for everything I load and run.... Is it because im still DEMO version or something? I did initial setup selecting native units IN.
DIY
  •  9,199 9,199
Re: Demo Gcode
« Reply #32 on: February 05, 2018, 01:43:34 AM »
Hi DIY,
It's nothing to do with using Mach3 in DEMO mode.
Scorpion.tap was prepared in metric (mm) units and the code contains the appropriate G21 command so it should have a dimension approx. 206mm x 235mm.
Could you please try the Axis Calibration feature (Settings page) and follow the on-screen instructions to check the calibration of your machine.
