Hello Guest it is July 30, 2025, 12:59:41 PM
Author Topic: Demo Gcode  (Read 281272 times)
andrewm
Demo Gcode
« on: May 03, 2011, 02:11:01 PM »
Assortment of Gcode files that are under 500 lines to test the demo with, Thought it would be a good idea to have them all in one easy to find place.
Thanks to those who made the files.
EDIT - When using any of these files please run a trial of the Gcode, just cutting air, to start with and if necessary use Notepad to edit the Gcode file to change the Feed-Rate or any other settings which may not suit your machine or cutting tool.
« Last Edit: February 23, 2021, 01:40:02 AM by Tweakie.CNC »
  •  9,303 9,303
Re: Demo Gcode
« Reply #1 on: May 04, 2011, 03:45:46 AM »
Great idea Andrew.  ;)
Re: Demo Gcode
« Reply #2 on: May 15, 2011, 06:40:01 PM »
Thank you!
andrewm
Re: Demo Gcode
« Reply #3 on: May 19, 2011, 01:44:50 PM »
Thanks. and NP :)
If anyone wants to add files to this either email them to me or post them here. I will reload the folder with them.
  •  9,303 9,303
Re: Demo Gcode
« Reply #4 on: June 02, 2011, 05:57:50 AM »
Found this one in my Mach folder - I have no idea of it's origin.
andrewm
Re: Demo Gcode
« Reply #5 on: June 02, 2011, 08:33:08 AM »
Thanks for sharing, its now part of the folder.
^_^
Re: Demo Gcode
« Reply #6 on: December 27, 2011, 05:19:39 AM »
THANK U so much AndrewM for this post by far the best post ever
 specially very helpful for a newbei like me :)
andrewm
Re: Demo Gcode
« Reply #7 on: January 11, 2012, 11:15:59 AM »
Glad I could help ^_^
Re: Demo Gcode
« Reply #8 on: June 05, 2012, 11:46:29 PM »
I use 7-zip to unzip my files. It is free and works great to unzip almost any format.
Thanks for sharing the files. Being new to this, I need some easy stuff to practice with so I don't have to try to create my own code for now....baby steps!!!
  •  9,303 9,303
Re: Demo Gcode
« Reply #9 on: October 12, 2012, 02:35:15 AM »
Hi Guys,
Here is a little project that falls within the 500 line limit for the Demo version of Mach3.
I am going back a few years but this is probably the first item I made with my CNC machine after it was built.
The GCode was produced with the free software G-Simple (sadly no longer available).
The cube was made from 1.8mm thick engraving laminate and cut with a 2mm dia. Endmill – the 6 pieces then slotted together and fixed with cyano super glue.
There are 2 versions of ‘Tweakie’s CNC Cube’ and I have included the Gcode for each in the .zip folder in post #1 of this thread.
« Last Edit: October 08, 2017, 01:36:39 AM by Tweakie.CNC »
