Hello Guest it is October 14, 2026, 06:52:18 AM
Author Topic: Mill orientation  (Read 31571 times)
Re: Mill orientation
« Reply #20 on: May 03, 2011, 04:20:36 AM »
Ok good I have all axis moving the right ways then. I will copy the XML when i get to the shop tonight.
Thanks again
Zc
« Reply #21 on: May 04, 2011, 08:00:42 PM »
I managed to get the mill oriented correctly tonight. In the input section. I had Home, ++ and -- all active for all 3 axis.
 as I only have switches on one end of the X & Y axis. I simply set the Home and X-- and Y++ inputs as active. this seems to have fixed the issue. when i would ref all home. i think it was getting confused. it seems to be working correctly now!
