Hello Guest it is October 20, 2026, 06:03:44 PM
Author Topic: Pulse engine noise  (Read 9444 times)
Pulse engine noise
« on: April 29, 2011, 02:54:08 AM »
What can I do to reduce the "Noise" on the parallel port test? I have time variation of 9-12us when using the pulse test engine. I am using a machine with XP Pro, Intel E4600 CPU, 1G ram. I have done the XP optimization but with no improvement.
The system will only be used for Mach3, no Internet or anything. Is there more I can do to try and improve the pulse engines consistency? The Mach3 config PDF doesnt actually say what to do if your system responds with spikes(unless I just can see it in the doc).
Re: Pulse engine noise
« Reply #1 on: April 29, 2011, 02:58:36 AM »
Have a look in the BIOS and see if there are any power saving options, I seem to remember Intel CPU based motherboards can have these options.
A PCI parallel port may help you but they can also have issues unless they are true parallel ports, most are but some are not.
  •  9,374 9,374
« Reply #2 on: April 29, 2011, 03:01:08 AM »
If you have onboard graphics this can cause problems. Some have disabled the onboard graphics in BIOS when they have fitted a PCI type graphics card.
