Hello Guest it is November 13, 2026, 05:23:49 PM
Author Topic: My SJ200 & Mach3 setup  (Read 36495 times)
Re: My SJ200 & Mach3 setup
« Reply #10 on: May 30, 2011, 10:01:58 PM »
Sure ..
You might notice a difference between the .jpg file a few posts up and the .brn file attached below ..
I had copied another persons file & then tweaked it to work for me .. not being sure what the last line did I just left it in.
I've since removed it and the brain still seems to work just fine so until I figure out why I should need it, I'll do without it.
« Reply #11 on: May 30, 2011, 10:33:25 PM »
Thank you Marsh.
