Hello
Guest
it is
November 07, 2026, 02:29:23 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Virtual Pendant / Jog Steps
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Virtual Pendant / Jog Steps (Read 18820 times)
Plastic Jim
9
on:
April 21, 2011, 07:16:33 AM »
Is there a way to bring up the Virtual Pendant or to change Jog Increments / Continious without using the keyboard? Hopefully something using the mouse? Thx...
Overloaded
4,923
Re: Virtual Pendant / Jog Steps
Reply #1 on:
April 21, 2011, 07:37:03 AM »
Hi Jim,
You can put this button on your screen with Screen4 which will bring up the pendant when clicked.
This works well on mine.
Russ
Plastic Jim
9
Reply #2 on:
April 21, 2011, 08:04:48 AM »
Thanx, but now i have to learn how to design a screen? Is there an easy way
Overloaded
4,923
Reply #3 on:
April 21, 2011, 08:08:41 AM »
Quite easy. You dont need to do a complete screen, just open the screen that you use with Screen4 (dwnlds section), place the button where you want it, then assign the OEM code to it. There are tut. videos but I have not watched them. Connection way too slow here.
Russ
Overloaded
4,923
Reply #4 on:
April 21, 2011, 08:10:42 AM »
Are you using the standard screen set ?
Mill or Turn ?
Which page would you want the button on ?
Overloaded
4,923
Reply #5 on:
April 21, 2011, 08:35:03 AM »
Here is where I put it on the Mill screen.
The screen set is attached if you want to try it.
Just put it in the Mach3 folder, then start Mach, click the View tab, select Load screens, then select 1024 Pendant.
Good luck Jim,
Russ
Plastic Jim
9
Reply #6 on:
April 21, 2011, 10:45:12 AM »
Russ,
Thank you!
J
Print
Pages:
1
Go Up
« previous
next »
