Hello Guest it is November 13, 2026, 09:44:44 AM
Author Topic: Index pulse in Lathe  (Read 47536 times)
Re: Index pulse in Lathe
« Reply #30 on: August 22, 2011, 04:32:33 AM »
You can make a tapered thread by specifying the taper in the wizard. I would need to  find my notes on doing it. The taper
input is "twice the angle" ,I think .......  just dont remember. The "T*********xx" in G76 defines the taper.  Been a long time since I  did one.
« Reply #31 on: August 22, 2011, 08:25:34 AM »
Then this is possible make threading conical.
Other restlessness when mach3 turn think implement timing pulse, namely several pulses por revolution of spindle?, i see several turn cnc and all use encoder in spindle.
This must be at least a few slots per revolution for more precision long threads. because several factors can alter the velocity of spindle in one revolution and the mach no informed of this.
thanks
Renato
« Reply #32 on: August 22, 2011, 09:50:17 AM »
When using the parallel port Mach just uses a single index when threading and it works well. There used to be an option for multiple slot discs but there was no real benefit to using them.
