Hello Guest it is November 17, 2026, 01:19:37 AM
Author Topic: Need help wiring a Keiling spindle and VFD  (Read 25897 times)
  •  9,377 9,377
Re: Need help wiring a Keiling spindle and VFD
« Reply #10 on: April 12, 2011, 07:17:19 AM »
Here are the connection details but as Hood has said you need the manual for firmware setting the max motor current etc.etc.
Surely no one would supply a VFD without the connection and setting-up details would they ?.
« Reply #11 on: April 12, 2011, 07:24:07 AM »
Thanks Tweakie,i don't know where you found that at,its at least a wiring diagram, more that i could get from Keling!maybe you should send him a copy.Thanks again Chris.
  •  9,377 9,377
« Reply #12 on: April 12, 2011, 07:30:50 AM »
But I am not sure it's any good without the VFD setup details because the default setting may enable too much current through your spindle so keep a close eye on the return water temp.
In practice the minimum connection is the 220V input, the spindle(U.V,W), the potentiometer between AM and ACM, and relay or switch between FOR and DCM
  •  9,377 9,377
« Reply #13 on: April 12, 2011, 07:37:40 AM »
Update.
Looking at my VFD instructions - you probably don't need the potentiometer as frequency is variable from the front panel - with luck yours should be the same.
