Hello Guest it is November 07, 2026, 03:54:15 AM
Author Topic: Bobcad-Turn and "Crop Circles"  (Read 16060 times)
« on: April 08, 2011, 01:40:15 PM »
Not sure if this is the right forum. I'm trying to generate some pretty basic output from Bobcad-Turn, and what looks like a normal tool path in Bobcad has all sorts of extraneous movements in Mach. Bobcad support calls it "Crop Circles" and they seem to think it has something to do with my Mach setup, since it doesn't show up in their sim. I can repeat the results with a default Mach3 install, though. They suggested I post Bobcad's output here to see if anyone knows what is wrong with it. I attached the output and a pic of what Mach sees when I load it. Thanks in advance - Jeff.
Re: Bobcad-Turn and "Crop Circles"
« Reply #1 on: April 08, 2011, 03:50:00 PM »
GO TO :
CONFIG>PORTS & PINS>TURN OPTIONS and tick or un tick reversed arcs in front tool post box
« Reply #2 on: April 09, 2011, 03:45:53 PM »
That worked, thanks!
« Reply #3 on: April 09, 2011, 03:49:36 PM »
There may be a setting in Bobcad or it's post processor but I am not familar with Bobcad.
Offline cfell
  •  27 27
« Reply #4 on: August 10, 2012, 06:33:29 AM »
Ref; BobCad-Turn and "Crop Circles" 4/8/2011.  This seems to be my problem G02/G03 appear to perform opposite intended in generated program.  How do I access and change configuration settings in Tormach Duality lathe version (screen set) of Mach3? -Charlie
« Reply #5 on: August 10, 2012, 03:48:37 PM »
Charlie,
Maybe someone on this site can help if they use that screen but contacting Tormach seems to be a good option to consider.
