Hello Guest it is September 18, 2026, 01:00:15 PM
Author Topic: Undocumented codes?  (Read 8703 times)
Undocumented codes?
« on: April 02, 2011, 05:22:38 AM »
Hello,
while I was looking at a basic script, I found a GetOEMDro(819). The comment says its getting the G0/G1 state. This DRO isn't documented in the Wiki and isn't on Bretts list. Is this an undocumented DRO, or is it just forgotten in the docu? If someone knows the answer, perhaps he knows also about the code 820.
Klaus
The brain isn't a soap, it doesn't shrink when used.
Re: Undocumented codes?
« Reply #1 on: April 17, 2011, 07:49:52 AM »
Hey Klaus,
   Yes 819 is the G0/G1 status,  BUT............  DRO 820 has been depreciated and is no longer valid.
scott
« Reply #2 on: April 17, 2011, 08:07:21 AM »
Hey Scott,
thank you for the answer. Since it took a bit longer, I placed the same question on the yahoo forum. I've got there the answer already from Brian.
Klaus
