Hello Guest it is November 13, 2026, 02:02:37 PM
Author Topic: Having a few issues with Mach  (Read 36362 times)
Offline SWATH
  •  48 48
Re: Having a few issues with Mach
« Reply #20 on: March 29, 2011, 09:14:26 PM »
Does mach use these?  Device manager says that they are not working properly and are experiencing problems.
« Last Edit: March 29, 2011, 09:17:09 PM by SWATH »
« Reply #21 on: March 30, 2011, 03:31:24 AM »
Your computer itself uses the system bus so it could well be your issue, try and find drivers for your motherboard chipset and that should clear that up.
Offline SWATH
  •  48 48
« Reply #22 on: March 31, 2011, 01:15:38 PM »
Ok I installed the chipset drivers so that alert went away, I still have the unknown device though.  The key to finding out what the problem is is identifying what is different between mach 3. 042. 020 and mach 3.043.022.  All the newer versions destroy my CPU but the old version does not.  How can I find this information?
« Last Edit: March 31, 2011, 01:20:26 PM by SWATH »
« Reply #23 on: March 31, 2011, 01:52:16 PM »
The driver did change, whether it was about that time I cant say , that could be having an effect but why the standard profile would be fine and yours not on the later version I dont know, that would also seem to point to the driver not being the issue.
Just dont really know what to suugest except maybe emailing support and getting Andrew to test things out as he has all the inside info.
andrewm
« Reply #24 on: April 01, 2011, 10:16:48 AM »
Please try loading the standard profile and modifying it to what your profile is running.
Offline jzak3
  •  25 25
« Reply #25 on: February 05, 2012, 02:52:08 PM »
Hello, I seem to be losing steps in my Z axiis, as it begins to cut, it starts out fine and as it continues on the material it starts to go deeper and deeper into the material. I am using 1/4 x 20 rod on my axis's and on the z I have it set for 8000  ex 15 and 7  I am in the process of rebuilding a new machine with much better materials and equipment, They should never tell any beginner to build one of these out of MDF board it turns out to be a waste of time and money.so if you can let me know what i can do to fix this problem i wouls appreciate it.
