Hello Guest it is November 01, 2026, 10:11:11 AM
Author Topic: LCam pdf is damaged & Clean copy can't be downloaded  (Read 9071 times)
« on: March 23, 2011, 09:37:16 AM »
Hi There just joined (I've owned Mach3/LCam) for a month now (didn't realise there was a Manual until now) imagine my frustration when the only thing is a 800k file that Acrobat says is damaged and it can't repair, Tutorial 8 in the same thread is OK I can open that but it would be nice to read the LCam manual partic the part about using it to process a drill file.
Regards
Stephen Lane
scottn
Re: LCam pdf is damaged & Clean copy can't be downloaded
« Reply #1 on: March 23, 2011, 09:44:40 AM »
Hi Stephen,
If it is only 800k, that is why Acrobat says it is damaged - the entire file should be 3.97MB, so it didn't completely download...  ;)
scott
« Reply #2 on: March 23, 2011, 10:31:39 AM »
Thanks for the prompt reply, Firefox starts a download as normal asking to save or veiw the file & dosn't matter weather its viewed or downloaded Acrobat says its damaged (the download says its finished & I've tried 3 times now) as I said I downloaded the Tutorial 8 OK and that opens and reads OK so I don't think its FF or Acrobat that leaves the 4Meg file ???
Regards
Stephen
