Hello Guest it is November 27, 2026, 11:37:25 PM
Author Topic: MACH3 STOPS AT ERROR " zero radius arcLine 502  (Read 10857 times)
« on: March 21, 2011, 12:51:19 PM »
machine just hovers over this point
is this a config setting that needs to be altered ?
HELP
Re: MACH3 STOPS AT ERROR " zero radius arcLine 502
« Reply #1 on: March 21, 2011, 01:57:11 PM »
More likely it is the code that is bad.
« Reply #2 on: March 21, 2011, 02:05:36 PM »
Post the line of code that are bad
Hard to tell with just the error code
This is a reply to the same problem at the zone:
Found the problem to be in the drawing, well I say that, I resolved the problem by redrawing one of the arcs.
The problem occurred where one arc joined another. Looking at the CAD drawing everything looked fine, the 2 arcs met exactly, however when the drawing was loaded into LazyCam and the offsets done there was a gap between the 2 arcs??
Found by loading the .tap file into NCPlot.
Interestingly the problem was not there before the offsets were done??
Jeff
