Hello Guest it is November 22, 2026, 02:29:01 PM
Author Topic: first gcode program not generating correct toolpath  (Read 32689 times)
Re: first gcode program not generating correct toolpath
« Reply #20 on: March 24, 2011, 04:47:52 PM »
To draw all the holes, you draw the first one at 0,0, origin
Then you use XFORM RECTANGULAR ARRAY
It will open a message box and you need to made 4 entries
Distance in the X direction and number on copy or entities
Distance in the Y direction and number of copy or entities
The double arrow is for changing direction
The rectangular array icon is 4 square dots.
Jeff
« Last Edit: March 24, 2011, 04:50:31 PM by ostie01 »
« Reply #21 on: March 24, 2011, 04:50:53 PM »
Ah, ok, that makes sense. Thanks for being so helpful. People like you make forums a great resource.
I'll see if I can duplicate your instructions when I get home from work.
