Hello Guest it is October 24, 2026, 11:18:51 PM
Author Topic: Hards, Homes, Limits, Softs, Slows, Offs.  (Read 23914 times)
Re: Hards, Homes, Limits, Softs, Slows, Offs.
« Reply #10 on: July 24, 2011, 04:15:16 AM »
Yes that is normal. There is no way Mach can know where it is until a Home has been done so there would be no way to know where to slow down.
Offline sebba
  •  42 42
« Reply #11 on: July 24, 2011, 07:39:00 AM »
thank for your fast reply Hood
yes indeed, it's true Mach don't know where is it until a home but in this case the slow zone is a little bit useless because when manually jogging the machine the operator should keep he's eyes there and see where the machine is moving
I'm thinking now for a procedure to have rapid movement for homing, something like zeroing the tool height in big-tex's blue probing screen set, in 2 steps.
first step at a higher speed, until home and then, after a short retract, the second step with slow speed for getting a higher accuracy.
I think an improvement like this will be useful at least for large machines with heavy gantries. If I'll have time and "inspiration" I'll give a try and post here the results. Hope will be positive. :)
Best regards,
Seb
« Reply #12 on: July 24, 2011, 07:55:27 AM »
This will home at the homing speed in Config>Homing/Limits, then home again at 1/10 the speed.
So if you set the Homing speed at 50%, it will home at 50% first, then 5%.
DoButton(24)
DoButton(23)
DoButton(22)
While IsMoving()
Wend
SetParam("XRefPer", GetParam("XRefPer")/10)
SetParam("YRefPer", GetParam("YRefPer")/10)
SetParam("ZRefPer", GetParam("ZRefPer")/10)
DoButton(24)
DoButton(23)
DoButton(22)
While IsMoving()
Wend
SetParam("XRefPer", GetParam("XRefPer")*10)
SetParam("YRefPer", GetParam("YRefPer")*10)
SetParam("ZRefPer", GetParam("ZRefPer")*10)
« Last Edit: July 24, 2011, 07:57:40 AM by ger21 »
Offline sebba
  •  42 42
« Reply #13 on: July 24, 2011, 09:18:02 AM »
wonderful! many thanks Gerry!
working perfectly
