Hello Guest it is November 01, 2026, 10:55:02 PM
Poll
Is there a basic tutorial how to config mach3 to run 5 steper motors?
I dont understand
0 (0%)
what this mean, sorry
0 (0%)
Total Members Voted: 0
Author Topic: my 5 step motors acting strangely  (Read 92726 times)
Re: my 5 step motors acting strangely
« Reply #10 on: March 02, 2011, 10:40:56 AM »
Now when I know how to atach stuff I can try to atach the doc with info about the card and so
« Reply #11 on: March 02, 2011, 10:47:29 AM »
Ok your xml is totally different from that document, I am heading home now but will be online again in an hour or two and will see if I can set up a xml for you to try.
« Reply #12 on: March 02, 2011, 10:50:57 AM »
Thanks, thats very kind of you!
« Reply #13 on: March 02, 2011, 01:11:18 PM »
OK give this a try, just save it to your Mach3 folder and then start Mach via the loader and choose the 5Axis profile.
« Reply #14 on: March 02, 2011, 02:56:57 PM »
Hello thanks for the try but I am afraid the motors and mach3 act exactly like it did before. I see that the new xml-file is like tree times bigger than the first one but I don't see any changes in the settings, what did you change?
« Reply #15 on: March 02, 2011, 03:07:05 PM »
I changed the pin asignments for the X, Y Z A and B axis for bothe Step and Dir.
When you load that xml do you see the name 5Axis down in the lower right of the screen/
« Reply #16 on: March 02, 2011, 03:07:51 PM »
Yes
« Reply #17 on: March 02, 2011, 03:09:27 PM »
That is strange that it acts exactly the same, will look at the doc again and see if I can find anything.
« Reply #18 on: March 02, 2011, 03:11:12 PM »
Did you change the settings in port and pins / motor outputs?
« Reply #19 on: March 02, 2011, 03:16:18 PM »
Because this settings are the same as in the xml-file I send to you, so maybe thats the reason.
