Hello Guest it is November 22, 2026, 11:03:18 AM
Author Topic: feed speed  (Read 9428 times)
feed speed
« on: March 01, 2011, 06:31:16 AM »
Is there any way to speed up feed beyond the overide?Even using the max override machine is still slower than i think it can go
Re: feed speed
« Reply #1 on: March 01, 2011, 06:41:14 AM »
Feed is commanded with the F word in your code, so for example if you had G1 X10 F100 it would move at 100 units per min.
Re: feed speed
« Reply #2 on: March 01, 2011, 06:45:53 AM »
adding to Hoods ... FRO only goes to 300%  of commanded feedrate.
If you want to go faster than that, and the max speed in motor tuning will allow, you'd have to increase the F feedrate in the code.
