Hello Guest it is October 02, 2026, 06:07:32 AM
Author Topic: mach turn od arc wizard  (Read 14232 times)
judah
« on: November 20, 2006, 12:56:45 PM »
hey dose any one know if the z end should be a neg number on mine there are no neg Numbers at all on the screen shouldn't there be?
 thanks
Offline PaulWC
  •  125 125
Re: mach turn od arc wizard
« Reply #1 on: November 20, 2006, 02:38:47 PM »
On my setup, Z+ is towards the tailstock and X+ is towards me.
When using the turn wizards, I just key in negative (-) values for Z, in the entry fields, when describing cuts towards the headstock.
Paul, Central OR
judah
« Reply #2 on: November 20, 2006, 02:54:29 PM »
mine will not let me cnange to a neg number its allways pos
Offline PaulWC
  •  125 125
« Reply #3 on: November 20, 2006, 04:11:32 PM »
Here's a sample I just ran... Mach3Turn ver R2.0.011:
Paul, Central OR
judah
« Reply #4 on: November 23, 2006, 02:55:05 PM »
ya see it  will let you enter  a neg number  in z end mine will not and your and also in your z center
                                               thanks for the help though any more ideas would also be appreciated.
I'm currently running Mach mill would this affect any thing?
Offline DAlgie
  •  314 314
    • Algie Composite Aircraft
« Reply #5 on: November 23, 2006, 08:18:42 PM »
Is it a mill or lathe you have? If it's a mill, don't use the turn wizards, if it's a lathe, you should be using Mach3 turn.
Offline PaulWC
  •  125 125
« Reply #6 on: November 24, 2006, 10:47:27 PM »
Hi Judah,
My setup is a P4, 2ghz, 1GB, Windows XP Pro SP2.
I'm currently running Mach3 ver RC2.0.013. When running Turn Wizards, I start Mach3 with "Mach3Turn.xml".
One more thing... I use my Numerical Ten Key Pad (right side of keyboard) for entering value signs (-), decimal point (.) and numbers... finishing with the "Enter" key on the bottom right corner. I don't know if there is any difference to the Wizard for which set of number keys are used?
Paul, Central OR
