Hello Guest it is November 19, 2026, 09:25:31 PM
Author Topic: Loosing steps when milling slowly  (Read 48303 times)
  •  9,378 9,378
Re: Loosing steps when milling slowly
« Reply #20 on: March 11, 2011, 04:36:41 AM »
What make and model driver board are you using for your steppers ?
« Reply #21 on: March 11, 2011, 04:51:37 AM »
Post info on your driver and motors.
What is the amp and voltage output of your power supply?
« Reply #22 on: March 11, 2011, 03:38:39 PM »
Hi.
My driver: http://cgi.ebay.com/CNC-3-Axis-Stepper-Motor-Driver-Controller-Board-TB6560-/270705528552?pt=LH_DefaultDomain_0&hash=item3f074e8ee8
the steppers: M57STH76-2808D-1 from: http://www.motioncontrolproducts.co.uk/products/2/5/nema_23_high_torque_stepper_motors/
Power supply is 24vdc 10A.
I know the driver is a bit cheap, but i am low on cash, and i have used a board a bit like this to drive a proxxon MF70 without any problems (using kcam).
I just don't get it.. it drives fine when running 1000 mm/min but runs like ********* when running for example 500mm/min.
« Reply #23 on: March 11, 2011, 04:11:41 PM »
What microstepping do you have set?
« Reply #24 on: March 11, 2011, 04:14:34 PM »
i have set it to 1/16 right now, but have tried with 1/8 and 1/2...
« Reply #25 on: March 11, 2011, 04:18:14 PM »
Is it all motors that are weird?
« Reply #26 on: March 11, 2011, 11:53:32 PM »
Yes all of them... they run quite smooth at 1000mm/min. But still looses some steps, but not like when running half the speed. But 1000mm/min is a bit to fast for cutting some materials.
« Reply #27 on: March 12, 2011, 03:15:14 AM »
what if you go half again?
« Reply #28 on: March 12, 2011, 04:07:21 AM »
Was it the same board and machine along with  the same drive  settings  you are using now and did you try slow speeds at that time when using Kcam via the PP?
Post your xml file.
« Reply #29 on: March 13, 2011, 01:29:15 PM »
It was not the same board, just a similar one... The settings are different, because it is a different machine. Slow speeds with the other cnc and kcam was possible without any problems.
I just tried to set the microstep back to ½ step. Apparently it works better... not loosing so many steps. But I just tried it quick, i will do an attempt some day next week to see if it really helps.
But is it normal that steppers runs smoother at high speeds?
