Hello Guest it is November 01, 2026, 10:10:23 AM
Author Topic: 49 lines Limit  (Read 17545 times)
49 lines Limit
« on: February 19, 2011, 10:37:22 PM »
Hi Everyone, I had received my Mach3 license from zentoolworks, but the lazycam only process 49 lines to mach3, the license was saved in mach3 folder, and I can process more than 500 lines in mach3 but the lazycam not. Sorry if the topic was solved before, I can't find it in the forum. Thanks for the help.
Gianni
Re: 49 lines Limit
« Reply #1 on: February 20, 2011, 06:14:00 AM »
Gianni,
 There is a 50 line limit in LC if you do not have a Mach license and also to use additional features in LC you will need a Pro license for LC.
What did you try to do in LC?
Re: 49 lines Limit
« Reply #2 on: February 20, 2011, 08:15:13 AM »
Hi Rich, I have a Mach3 license, I am only doing a letter from a dwg file, when I try to export to mach3 it only give me 49 lines.
Re: 49 lines Limit
« Reply #3 on: February 20, 2011, 08:39:01 AM »
Post your xml file.
scottn
Re: 49 lines Limit
« Reply #4 on: February 20, 2011, 08:45:44 AM »
I'm pretty sure that LazyCam is not seeing the Mach license file.  I think that Zen Toolworks distributes their licenses with the serials still attached at the end (ie. "Mach1Lic.dat.******************"), which Mach can now recognize, but LazyCam does not...
scott
Re: 49 lines Limit
« Reply #5 on: February 20, 2011, 08:52:54 AM »
Scott,
Any fix to that problem?
Re: 49 lines Limit
« Reply #6 on: February 20, 2011, 12:14:57 PM »
scott
Could you just place the normal "Mach1Lic.dat" in there along with the other one ?
Zen would see what it needs and LCam would see what it needs.
Just a thought,
Russ
Re: 49 lines Limit
« Reply #7 on: February 20, 2011, 06:16:32 PM »
Thanks, it was the problem the license come with serial in the file name, removing it and the problem was solved. Thank you very much
Gianni
Re: 49 lines Limit
« Reply #8 on: February 21, 2011, 05:36:54 AM »
SO you removed the serial part out of the file name?
Re: 49 lines Limit
« Reply #9 on: February 21, 2011, 08:53:23 AM »
Yes Rich Thanks, that was the solution. Regards
Gianni
