Hello Guest it is November 24, 2026, 08:02:42 PM
Author Topic: Need help with basic understanding  (Read 74986 times)
  •  9,378 9,378
Re: Need help with basic understanding
« Reply #30 on: February 21, 2011, 02:22:52 AM »
Don't rely too heavily on Sketchup it was never designed for CNC and may not be doing the best job.
« Reply #31 on: February 21, 2011, 04:02:58 AM »
OK well. I mounted the laser on the machine nice and steadily, it doesn't move at all now. I also ran the steps per calibration a few times on both axes, and they matched up exactly the same every time.
So not really sure what else could be wrong with it now, apart from software.
Cheers,
  •  9,378 9,378
« Reply #32 on: February 21, 2011, 04:11:37 AM »
Dan,
Which software do you think is causing the problem ?
« Reply #33 on: February 21, 2011, 04:16:41 AM »
Well that I'm not exactly sure on. The page before, the g code I was using was proven to be OK, and I can create some text in lazycam and it'll draw it all fine. Maybe mach3 is interpreting the code wrong? Or maybe there is a setting (offset or something) that mach3 doesn't like?
Does anyone have any proper CAD software they know works with their machine, who could create a dxf or some gcode for me to try?
Cheers,
« Last Edit: February 21, 2011, 04:22:17 AM by Things »
« Reply #34 on: February 21, 2011, 05:20:35 AM »
Can you post the dxf you used from Sketchup?
  •  9,378 9,378
« Reply #35 on: February 21, 2011, 05:24:51 AM »
This logo has just been downloaded from "Brands of the World".
Loaded in Lazycam and toolpath produced.
GCode and dxf attached - see what you can do with it.
(this has been set up for my vinyl cutter so you will need to edit the Z in the GCode  and scale etc. to suit your machine)
« Reply #36 on: February 21, 2011, 06:20:48 AM »
Here is how it turned out:
So, it would appear the problem is either in my electronics, or my mechanics.
Does anyone know any guides that could help me narrow down the problem? Or any gcode/tests I can run to help?
Is it possible microstepping could be playing a part in this? I have the controller (Pre-made, generic 4 axis board) set on 1/8 microstepping. I really do like it as it makes everything a lot quieter and smoother, not to mention more accurate, but if its causing me problems I may need to find another solution. But I'm was under the impression almost everyone used mcirostepping without problems?
I built this whole machine myself, and this teeny little glitch is all thats stopping me from finally completing it.
If hi res, detail pictures of the machine will help, I'm ready with the camera.
Cheers,
« Last Edit: February 21, 2011, 06:23:26 AM by Things »
  •  9,378 9,378
« Reply #37 on: February 21, 2011, 06:52:58 AM »
Apart from the obvious it came out very well.
On the 'R' you have a vertical shift and on the 'A' a horizontal shift so the problem is occuring on both axis.
Surely that gap is too large for missing steps (how many steps would have to be missed, consecutively, for a gap that large?) so something loose on your machine ? or your PC multitasking ? or drive belt jumping a tooth ?. I think you need to be extremely methodical in testing this to discover the cause, just try one thing at a time until you find it.
Best of luck.
« Reply #38 on: February 21, 2011, 06:55:45 AM »
Do you still have the steppers being used as idlers? Could that be the problem as they may partially lock for a split second every now and then.
  •  9,378 9,378
« Reply #39 on: February 21, 2011, 07:20:51 AM »
Dont know if it's any help to you but attached is the GCode file (thanks to Sam) I used for initially testing my laser. (it is Inch units so you may need to scale it)
http://www.cooperman.talktalk.net/laser1a.wmv
