Hello Guest it is November 25, 2026, 05:38:35 AM
Author Topic: Fourth Axis  (Read 7302 times)
Fourth Axis
« on: February 16, 2011, 07:38:05 PM »
I have added a fourth axis to the Series 1 and have been through the ports and pins and motor tuning and have it performing smoothly.
I have been controlling it with the "4" arrows in the flyout. Is there a standard hotkey for the A axis? I assume I will need change the 999 to a
hotkey.
I do not have a limit or home switch yet, so when I attempt to calibrate it the revolutions it makes are not easily measured. Can the DRO readout be used to bracket the 360 degrees of rotation?
If you think you can't do it, you're right.
