Hello Guest it is October 21, 2026, 10:55:02 AM
Author Topic: Hesitation between Lines of G-code  (Read 37265 times)
Re: Hesitation between Lines of G-code
« Reply #20 on: February 25, 2011, 07:50:52 PM »
Ok tried the code with your xml and I dont see any hesitation in the toolpath view or by watching the units per min DRO. Can you run the driver test and see what that is like.
The IJ mode is set with G90.1 or G91.1, the code you posted is Inc IJ mode so G91.1 would be inthe header.
« Reply #21 on: February 25, 2011, 11:06:16 PM »
Hi Hood,
Thanks for checking that out. What's the driver test? Seems like I'm discovering new Mach features all the time...
Thanks for the G Code tip too. I'll change my header in my post and config.
