Hello Guest it is November 24, 2026, 02:27:56 PM
Author Topic: HOME should zero the Z axis before the X&Y axis  (Read 57854 times)
Re: HOME should zero the Z axis before the X&Y axis
« Reply #10 on: April 24, 2011, 07:00:29 AM »
I'm thinking home all would move all axes at the same time. You'd probably be best to hand code moving Z first
By Default, Ref All does one axis at a time. You can modify the script to home all axis at once using the RefCombination function.
« Reply #11 on: July 01, 2011, 08:32:47 AM »
I have Romaxx HS1 and the custom Romaxx set which you can freely download has 2 buttons, 1 to zero Z and other to zero XY, you can download it from the web http://www.romaxxcnc.com/screens.html and see for yourself how the buttons are programed and then do the same or similar. I believe its a very clever solution
