Hello Guest it is November 22, 2026, 08:26:26 AM
Author Topic: Newbie. What am I doing wrong?  (Read 24148 times)
Re: Newbie. What am I doing wrong?
« Reply #10 on: February 11, 2011, 08:40:21 PM »
Okay
It was too long for code tags so I have uploaded the file itself.
Be gentle with me, I dont know a great deal about gcode yet.
« Reply #11 on: February 12, 2011, 03:19:31 AM »
Looks fine to me, heres a screenshot, is this what you expect?
If it is then can you attach your xml please.
« Reply #12 on: February 12, 2011, 03:46:17 AM »
This is the one renamed.
And yes, that is what I expected to see but not what I get when I open it.
« Last Edit: February 12, 2011, 03:59:19 AM by No1Daemon »
« Reply #13 on: February 12, 2011, 04:56:30 AM »
Ok first thing you are using Demo mode so you are restricted to 500 lines of code so you will only see a very small part of the file. You are also in table view so that is likely why its way off in the distance, click diplay button then regenerate and your should see it closer, however as said you will just see 500 lines worth as below.
Offline Mattw
  •  41 41
« Reply #14 on: February 12, 2011, 09:39:21 AM »
Nametags for the kiddies was my first CNC project too.  I figured that made up for the year of utter neglect while I got the machine running.  ;D
« Reply #15 on: February 12, 2011, 12:15:09 PM »
Thanks Hood.
Appreciate your help
