Hello Guest it is August 29, 2026, 01:30:05 PM
Author Topic: MachStdMill Screen CV and ES button  (Read 8502 times)
« on: February 05, 2011, 07:44:00 PM »
On the run screen, when I use exact stop in my program (G61) it's the CV button that is highlighted and when I use G64 for constant feed, that's the ES button that is highlighted.
I need to use both G64 and G61 in my program.
The code are accepted . The machine runs fine, just button that are inverted.
Jeff
Re: MachStdMill Screen CV and ES button
« Reply #1 on: February 09, 2011, 03:57:03 PM »
Jeff,
What version of MSM are you using?
I just checked and with the current version of MSM G61 gives ES and G64 gives CV and the two buttons/LEDs are not swapped.
BTW - I just happened to see your post here - the best place to get MSM questions answers is www.calypsoventures.proboards.com
Jeff
www.CalypsoVentures.com
