Hello Guest it is October 21, 2026, 07:04:06 AM
Author Topic: New CNC Router Start up Problem  (Read 67734 times)
Offline kolias
  •  1,165 1,165
Re: New CNC Router Start up Problem
« Reply #10 on: January 30, 2011, 05:04:41 PM »
Best to start your checking by unhooking the cable and putting the meter direct to the port.
Thats what I was planning to do
Nicolas
Offline kolias
  •  1,165 1,165
« Reply #11 on: January 30, 2011, 05:35:38 PM »
Something I dont get. If I unhook the printer cable from the BOB how am I supposed to jog the motors?
Nicolas
« Reply #12 on: January 30, 2011, 05:41:50 PM »
Just pretend you are jogging them :) All you are looking for is whether Mach is changing the state of the Direction pin on the port. So as long as you press the arrow key one way then press the other arrow key then Mach will think it is jogging the motor, the DRO will move and hopefully your voltage will change as you change jogging direction..
Offline kolias
  •  1,165 1,165
« Reply #13 on: January 30, 2011, 05:46:01 PM »
ok so you want me to check the printer port on the Laptop and not the BOB
Nicolas
« Reply #14 on: January 30, 2011, 05:48:02 PM »
Yes.
Offline kolias
  •  1,165 1,165
« Reply #15 on: January 30, 2011, 05:49:21 PM »
I'm on it, hopefully I will not blow any fuse LOL
Nicolas
« Reply #16 on: January 30, 2011, 05:52:54 PM »
Hope not, there are not any fuses to blow ;D
Offline kolias
  •  1,165 1,165
« Reply #17 on: January 30, 2011, 06:01:35 PM »
Nothing moves, voltmeter shows nothing and DRO's dont change
I checked betwen pins 3, 5, 7, 9 and the ground (each one individually)
Looks like mach3 is dead, maybe the mach3 installation is something wrong?
Nicolas
« Reply #18 on: January 30, 2011, 06:08:12 PM »
Ok, look at Diagnostics page, do you see a pulse frequency there?
Also have you definitely got the correct port address set for Port 1.
If you attach your xml I will have a look and see if there are problems with your config.
Offline kolias
  •  1,165 1,165
« Reply #19 on: January 30, 2011, 06:15:25 PM »
The Pulse Frequency is 100
The Port #1 is enabled and in my Laptop the system says the LPT1 port is functioning properly
Please see my XML attached
Nicolas
