Hello Guest it is November 21, 2026, 03:19:21 PM
Author Topic: How to reverse servo's in Mach or DSPMC software  (Read 31148 times)
« on: January 25, 2011, 01:37:39 AM »
Please advise how to reverse the servo directions in a MACH/DSPMC setup.
Changing the dir in PORTS and PINS in motor setup does not have any effect.
Regards
Graham
Re: How to reverse servo's in Mach or DSPMC software
« Reply #1 on: January 25, 2011, 04:12:19 AM »
Hi Graham,
Go to the config tab then homing/limits. Change the red x to a green check mark in the reversed column.
Mike
« Reply #2 on: January 25, 2011, 10:16:43 PM »
Hi Mike,
Thanks we tried that today and it worked.
Can I respectfully suggest that some of these practical setuo issues should be in your manual>
Recerse direction and how to set up Slave Drives are 2 issues we have had on our current project!!.
« Reply #3 on: January 26, 2011, 03:57:26 AM »
Hi Graham,
While I did some work on the early manual I no longer update it since I don't work for Vital system.
I agree it would be a great idea to improve the manual with your suggestions and others that have come in from the forum.
I am unfortunately too busy to keep up with my own stuff at the moment so I can't do it even if asked.
When and if it slows down around here I will take a look at it, if not Rufi would be the person to make suggestions to.
I will answer questions on the forum as time allows as always.
Mike
« Reply #4 on: January 26, 2011, 03:59:45 AM »
I miss posted in the wrong forum.
My falt for having too many tabs open at the same time.
