Hello Guest it is October 24, 2026, 03:53:06 AM
Author Topic: Rack and Pinion Reduction Drives  (Read 10797 times)
« on: January 24, 2011, 10:46:02 PM »
I made some rack and pinion reduction drives for my new project.
6061 aluminum with 120/19 Gates GT2 3mm belts and pulleys.  Final ratio is 6.32, and after the 20 tooth rack gear I'll have about .50 IPT.
It's a Nema 23 setup. :)
  •  9,374 9,374
Re: Rack and Pinion Reduction Drives
« Reply #1 on: January 25, 2011, 01:25:38 AM »
Very nice work Michael.
How are you getting the tension on the drive belt ?
« Reply #2 on: January 25, 2011, 08:40:10 AM »
Well.....the first design had an idler that also put more wrap on the small pulley.  It turned out to be unnecessary and just added a lot of drag.  The belt maintains 7 teeth engaged without the idler, and is adjusted by slotted mounting of the stepper.
« Reply #3 on: January 25, 2011, 01:01:13 PM »
Nice craftsmanship!
