Hello Guest it is October 14, 2026, 05:08:03 AM
Author Topic: Mach3Turn Offsets?  (Read 156544 times)
Offline Leeway
  •  149 149
    • LeeWay Workshop, LLC
Re: Mach3Turn Offsets?
« Reply #120 on: October 28, 2014, 04:56:01 AM »
Well,I ran some of the old code output by V10 and it used your unmodified PP that you gave me earlier in this thread.
The spindle acts exactly as it should in that file. It regulates to initial speed and then continues steadily during that operation. Changes to the next called speed on the next op. This is as it should be.
V13 is definitely doing something different.
I thought it might had been a Mach 3 settings somewhere, but nope.
I will compare texts files and see what the difference actually is. I'll then post the results here.
Lee
« Reply #121 on: October 28, 2014, 07:34:11 AM »
Not sure how that could be as the code you showed didnt have a G96 in it and that is the only way I can think of that the spindle speed could vary whilst cutting.
Look forward to what you find out.
