Hello Guest it is November 13, 2026, 08:08:40 PM
Author Topic: Wiring Limit & Home Switch  (Read 61960 times)
Re: Wiring Limit & Home Switch
« Reply #30 on: February 09, 2011, 07:46:24 AM »
Do you have a Z Home switch? If yes then you wont be screwing about with Homing without Home switches ;)
If you dont then the axis will not move when you do a RefAll.
Not read the doc but if you want to home without switches you need to manually move the axis to a known position before you press the Ref All.
Offline kolias
  •  1,165 1,165
« Reply #31 on: February 09, 2011, 11:03:42 AM »
Sorry Hood, my mistake
I do have two limit switches on the Z axis but they both share the same pin number on the BOB and so I cant consider one of them as a Home switch
Thank you
Nicolas
« Reply #32 on: February 09, 2011, 11:12:00 AM »
You can use one as a home switch :) Just set the Z home to same port and pin as the Z Limits use.
  •  9,377 9,377
« Reply #33 on: February 09, 2011, 11:16:18 AM »
You can use your limit switch as a home switch because when set-up the axis will only home in the one direction.
(In answer to your earlier question re soft limits - the axis would home to the 0.25" position because that is the figure Rich specified in his setup).
Offline kolias
  •  1,165 1,165
« Reply #34 on: February 09, 2011, 12:05:25 PM »
 I did this but the axis moves in the plus direction when I hit the Home button. I switched on the Active Low but then I get a message that one limit is one and I have to press reset
The keyboard arrows move the axis correctly.
How can I get the axis to Home in the negative direction?
Nicolas
« Reply #35 on: February 09, 2011, 12:36:47 PM »
The Z should move in the positive direction when you home, ie up the way. Homing down the way is not a good thing to do as it would cause problems with the spindle fouling clamps. work pieces or even the table.
Offline kolias
  •  1,165 1,165
« Reply #36 on: February 09, 2011, 06:21:13 PM »
The Y and Z axis are Homing ok now but the X axis was Homing in the wrong direction
So I went to the Motor Home/Soft Limits and un ticked the Home Negative like the Z axis
I wonder why the X axis was Homing in the wrong direction
Also on the same screen I have set the Slow Zone to 2.00 and the Speed % to 20. I understand that the Slow Zone means when the axis approaches the 2.00 the speed will be reduced to 20% until she hits Home. But this does not happen, no matter where the axes are when I Ref Home they start moving to Home at the 20% speed. What I do wrong?
Nicolas
« Reply #37 on: February 09, 2011, 06:41:12 PM »
Slow zone is for soft limits, not homing.
