Hello Guest it is September 30, 2026, 02:25:56 AM
Author Topic: Bug or Feature?  (Read 11387 times)
Bug or Feature?
« on: January 12, 2011, 03:23:25 AM »
Hi
since i have installed the pokeys-plugin, mach3 can only work with controller plugged in. when my controller is plugged off, the reset button don't work and i can't use mach.
I have no E-Stop buttons or so.
Bug or feature?
off Topic:
since yesterday I can't open the 'motor tuning dialog' also the 'calibrate spindle dialog' wants not open.  klick on it and nothing happens, don't now why... )-:
Re: Bug or Feature?
« Reply #1 on: January 12, 2011, 08:48:22 PM »
Feature,
     Andrew of "Mach Motion", wanted Mach3 to "Estop" if the PoKeys became unplugged, since they use it for both HMI and Pendant....
it was added as a safety feature. If you want to disable that, and run mach without the PK plugged in, then Disable the plugin.
as to your other questions, unknown, dont see that here.
scott
Re: Bug or Feature?
« Reply #2 on: January 13, 2011, 05:22:51 AM »
thanks for replay. yes, disabling the plugin is a solution but it would be nicer if you can choose your way...
the other problem was solved by reinstalling mach, however.
