Hello Guest it is November 07, 2026, 12:41:02 PM
Author Topic: edit button script will not save in R3.042.040  (Read 44600 times)
Offline miket
  •  18 18
Re: edit button script will not save in R3.042.040
« Reply #20 on: January 16, 2011, 01:14:49 PM »
With Mach3 active I just open explorer window to check if the date of the *.set file is being updated.
It's not with keygrabber.exe /p etc  mode and it is with mach3 /p etc
« Reply #21 on: January 16, 2011, 01:30:45 PM »
Ok if you press Save Settings on the Config menu it should update the date stamp. Lots of  things you change in Mach are not updated until you shut Mach down, unless you actually save them whilst Mach is open by using that Save Settings option.
Offline miket
  •  18 18
« Reply #22 on: January 16, 2011, 02:54:15 PM »
I did all that but no joy. I assume by the way that after editing a macro and opening it again the changes should be
visible without saving anything - not in my case with this keygrabber.
Also, i am pretty sure the last ime i used 'edit macro' with keygrabber was about a year ago and it worked then.
« Reply #23 on: January 16, 2011, 04:00:19 PM »
Dont have a clue what could be going on, if I edit the button, save and close then go back in it has still got the changes. Occasionally if you dont go to File then Save in the editor it will not change but that can happen with or without keygrabber.
Offline miket
  •  18 18
« Reply #24 on: January 19, 2011, 01:40:14 PM »
I have noticed the following:
Edit button script - change the file then 'File save' then exit window
Then, 'VB script editor' - opens the previous file with the correct changes
Then Edit button script - no changes in file
What's going on with the Keygrabber?
