Hello
Guest
it is
October 31, 2026, 05:02:06 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
tool change
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: tool change (Read 11501 times)
lajoolaj
5
tool change
on:
January 08, 2011, 11:10:43 AM »
i am useing mach3 mill. when i do M6 T2 program stop and waiting for cycle start. it is ok but when i press cykle start spindle dont start. what is wrong?
sorry my bad english
Logged
BR549
6,965
Re: tool change
Reply #1 on:
January 08, 2011, 11:16:30 AM »
A tool change normally does not restart the spindle. It is normally restarted via Gcode after the machine clears the tool change area .
YOU can alter the M6end macro to auto restart the spindle .
To the M6end add DoSpinCW() to the end of the file. Just remember it willl autostart the spindle EVEN if it is not where you want it to be(;-)
Hope that helps, (;-) TP
Logged
ger21
6,295
Re: tool change
Reply #2 on:
January 08, 2011, 11:48:51 AM »
Yes, be careful with having the toolchange macro start the spindle.
I was doing that with my auto zero macro (as part of M6) UNTIL the spindle started unexpectedly.
At that point, I decided to let the g-code start the spindle.
Logged
derekbpcnc
195
Re: tool change
Reply #3 on:
January 08, 2011, 02:35:11 PM »
Safer to write in your Gcode:-
T2 M06 (Tool change to tool 2)
G43 H2 (apply tool lenght offset if you have programmed the tool table)
M03 S1000 (turn spindle on and set speed)
ATB
Derek
Logged
You can "chop it off" but can't "chop it on"
Print
Pages:
1
Go Up
« previous
next »
