Hello Guest it is November 04, 2026, 01:02:28 AM
Author Topic: Spindle speed not changing until overide button pressed  (Read 40947 times)
Re: Spindle speed not changing until overide button pressed
« Reply #20 on: January 13, 2011, 06:35:36 PM »
IF you ran the 1024 screen and it did the same thing that would eliminate anything screen related and tends to point to an automated process still running.
Just a thought, (;-) TP
Offline tmead
  •  62 62
« Reply #21 on: February 11, 2011, 04:43:48 AM »
Sorry for the delay - new job means this has taken a back seat fro a while.
I took a good look last night, and still have no idea ! I disabled the macropump and loaded the unmodified 1024 screenset, the reaction was still the same - any spindle S words were accepted, the DRO was updated, but the physical spindle speed did not change until a spindle speed override button was pressed.   >:(
i gave up ! :'(
The xml and other bits/pieces were copied out, and a complete uninstall/reinstall of mach completed, using the same version (3.042.025). It works now !  ;D
So, as I said - I'm no further forward in fault diagnosis, but the symptoms are fixed, using the same macropump, same gcode, same bitmaps and same screenset. There must have been a setting in there somewhere that i'd accidentaly changed.   ???
Anyway - thanks for all the people that thought about this, and offered suggestions.
Tim
« Reply #22 on: February 11, 2011, 07:47:04 AM »
Sounds like the same problem others have reported, yet unresolved.      http://www.machsupport.com/forum/index.php/topic,9314.0.html
I am having the same problem myself now on a new lathe build.  No cure/fix in sight.   This one has been around and I found reports back to 2007
ALSO..... try issuing a duplicate S*********x command, that will also cause the speed to go to the correct commanded value.   Its only the FIRST M3 S********* command that intreprets wrong.  All subsequent speed commands execute properly!!
Another data point worth noting :   So far, EVERY report of this I have seen has been with a PWM controlled spindle.   Step/Dir controlled spindles have not had the issue.   Is yours PWM controlled?  (bet it is ! )
« Last Edit: February 11, 2011, 07:55:29 AM by Sparky_NY »
Offline thosj
  •  542 542
« Reply #23 on: February 11, 2011, 04:30:34 PM »
I have no problem seeing this. It's been there for months, at least. Initially there was some mention of the bug, but it's died a peaceful, unfixed, death. There's a doc out on the web someplace penned by Chris Humphris, dated July of 2010, on how to setup a PWM spindle and that's where I first saw this mentioned.  Top of page three, big as life for all to read, and it has it exactly as stated here and everywhere else.
http://www.cnctar.hunbay.com/HJozsi/Mach3/PWM%20Spindle%20Control%20using%20Mach3.pdf
I've given up on it getting fixed and just live with it, but mine only changes by 4/5%!! Life is too short and EMC2 is too big a PITA/learning curve to switch!!! But I always consider it when this stuff comes up and goes unfixed. But.............just wait for Mach v4, by George.
Tom
Tom
« Reply #24 on: February 11, 2011, 05:02:24 PM »
Hang in there Tom !     I got Brians attention on this and he is looking at it right now.    I am betting a fix will be out very fast.
Offline tmead
  •  62 62
« Reply #25 on: February 14, 2011, 06:11:11 AM »
Thanks for all the comments !
The machine runs with a step/direction spindle, so is perhaps a little different to the PWM issue ?
The key feature that we've seen is that the spindle will only run at the previous speed when an M3 S ********* is issued, although the DRO will show the requested speed. There is no change until a spindle speed override is pressed, then it picks up the new speed as shown on the DRO. I have not tried running a VB script that issues an S word, pauses and then issues the relevant DoOEMButton........ that might have been a work-around !
However, a complete removal and re-install of mach3 fixed the issue. (remembering to grab a copy of the xml, macros, bitmaps, and gcode directories first  ;)  )
Tim
« Reply #26 on: February 15, 2011, 02:28:59 PM »
Offline thosj
  •  542 542
« Reply #27 on: February 15, 2011, 05:45:07 PM »
Seems good here, too! Two fixes for me in one day.
My 8 speed BP now has 4 pulleys that run in reverse as they should, and speed comes up at the speed it should be and stays there.
Great, thank Brian!!
Tom
Tom
