Hello Guest it is October 21, 2026, 07:04:12 AM
Author Topic: DB-200S Spindle USA  (Read 35792 times)
Offline kolias
  •  1,165 1,165
Re: DB-200S Spindle USA
« Reply #20 on: February 26, 2011, 07:20:59 PM »
Thats great Gerry, wonder if there is any danger for motor overheating at low RPM
But reading they say is not good for variable speed control routers, although they say its possible to disable the VS but dont know if it will be easy
Is this made in USA
Anyone is using it?
Nicolas
« Reply #21 on: February 26, 2011, 07:44:52 PM »
Yes, you have to disable the built in variable speed.
It's made in Australia.
I'm using one on a Porter Cable 690.
It can overheat if you push it too hard at very low rpms. However, I've found that it runs much cooler than stock, as it uses less power under most conditions. The SuperPID only supplies enough current to maintain the rpm.
Offline kolias
  •  1,165 1,165
« Reply #22 on: February 26, 2011, 08:31:38 PM »
Thanks Gerry, sounds good but I have got to think how it suits my needs.
I like the SuperPID but I also like the spindle I posted before. So I have to decide which one is best for me.
Much appreciate your help
Nicolas
