Hello Guest it is October 03, 2026, 02:27:37 AM
Author Topic: Macro Controlling Multiple Outputs  (Read 21339 times)
« on: November 11, 2006, 03:16:10 AM »
Hi, I'm new to this forum, but I have been a Mach user for 2 years, just that I didn't really  play with macros. I'm setting up a oxy control, which control valves of oxy. and acet., to suit the traditional cutting style. As you can see, there are ignition delay, preheat delay and pierce delay, and 3 of them are controlled by 3 different outputs. The problem i'm facing is everytime i trigger this macro script, all the outputs triggers at the same time. I cant get it to delay before triggering another output. Can someone kindly help to neaten up the script? Thanks!
rem  M3 Macro
Dim IgnitionDelay, PreheatDelay, PierceDelay
IgnitionDelay = getUserDRO (1001)
PreheatDelay = getUserDRO (1002)
PierceDelay = getUserDRO (1003)
ActivateSignal(Output1)
code "G4 P" & (IgnitionDelay)
ActivateSignal(Output2)
code "G4 P" & (PreheatDelay)
ActivateSignal(Output3)
code "G4 P" & (PierceDelay)
End
Re: Macro Controlling Multiple Outputs
« Reply #1 on: November 11, 2006, 08:09:19 AM »
This is what I like to see :) you tried and all I have to do is a little work to the script! You get a star for the day ;)
Okay you are VERY close to haveing what you need... this should work for you:
Rem  M3 Macro
While IsMoving()
Wend
While IsMoving()
Wend
While IsMoving()
Wend
End
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: November 11, 2006, 08:24:51 AM »
Whoa! Thanks!!!! I've been waiting for this moment for a long, long time! Thanks!!!
What's the difference between WEnd, Sub End, and End?
« Reply #3 on: November 11, 2006, 12:11:42 PM »
Sub End is to end a Subroutine
Wend is the end of a While loop
End ... there is no end :) There is an End if and this tells the end of an if statement
Brian
www.machsupport.com
« Reply #4 on: November 14, 2006, 03:38:57 AM »
While your on about controlling outputs, how do you turn them off.
Chris
« Reply #5 on: November 14, 2006, 06:28:54 PM »
DeActivateSignal(Output3)  That will do it  :o
www.machsupport.com
« Reply #6 on: November 14, 2006, 06:30:04 PM »
I've sorted it, I was been dumb, if anyone wishes to know it's simple really DeActivateSignal(output5)
This is what I'm trying to do.  Hopefully it will turn my spindle on on my bridgeport series 1 boss machine when I wire it in.
M3.m1s
If (GetOEMDRO (56) = 1) Then
DoSpinCW()
ActivateSignal(Output5)
Message "Spindle Start Requested"
SystemWaitFor(Input2)
While IsMoving ()
Wend
Message "Spindle Start Delay"
Code "G4 P2"
While IsMoving
Wend
Message ""
Call SetUserLED(1010,1)
End If
If (GetOEMDRO (56) = 2) Then
DoSpinCCW()
ActivateSignal(Output6)
While IsMoving ()
Wend
DeActivateSignal(output6)
Code "G4 P2"
While IsMoving
Wend
Message ""
End If
It's a bit long but it seams to work when I simulate it, the M4 ones the same but the other way around.
Chris
« Reply #7 on: November 14, 2006, 06:40:06 PM »
No problem :) Looks like you are getting it!
www.machsupport.com
