Hello Guest it is November 22, 2026, 08:07:09 AM
Author Topic: Error in pocket wizard  (Read 7521 times)
Offline Sage
  •  370 370
« on: December 18, 2010, 09:09:59 AM »
In the standard built in Mach wizards (called "conversational on my screen set") the circular pocket wizard has the milling directions mis-labeled.
If you select CW the direction of travel of the tool is actually counter-clockwise.
Bottom line:
The top selection is CW (climb)
The bottom selection is CCW (conventional)
Only the CW and CCW descriptors need to be swapped.
The climb and conventional descriptions are actually incorrect as well for an internal pocket i.e counter-clockwise is climb milling, but changing the CW and CCW names only will take care it.
Confusing.
Sage
