Hello Guest it is November 13, 2026, 05:01:46 PM
Author Topic: 4th axis question  (Read 26859 times)
Re: 4th axis question
« Reply #10 on: December 16, 2010, 11:03:37 PM »
by the way, the G code is so big because I had to turn coordinate modal off in VM or it caused other issue's with this model.
Offline Greolt
  •  956 956
« Reply #11 on: December 17, 2010, 01:47:12 AM »
Looks like fairly poor code but that may be because we are only seeing a small section.
Try some basic code like this and see if you get a better result as far as A axis feedrate is concerned
G21
G1 Z25 F500
A90
Z50
A180
Z75
A270
Z100
A360
A axis feedrate should decrease as Z height increases.
I made this in metric because I think you said that is your native units.
Greg
EDIT:  I reread your posts and maybe your native units are medieval english.  :)
If that is the case then try this code instead.
G20
G1 Z1 F20
A90
Z2
A180
Z3
A270
Z4
A360
« Last Edit: December 17, 2010, 02:02:06 AM by Greolt »
« Reply #12 on: December 20, 2010, 11:08:27 AM »
Thanks Greolt, radius correct work fine with basic code like that, Z height, then rotate. Were I'm having trouble is when A axis is rotating while Z is moving at the same time. It should work the same shouldn't it?
Ray
Offline Greolt
  •  956 956
« Reply #13 on: December 20, 2010, 06:07:50 PM »
My understanding is that the feedrate correction will update with each line of code.
It's possible that my understanding is not correct.
I have not seen this issue but that might be because I do not machine jobs like cams.
Zip up your code and post, and I will run it here to see if I get the same result as you.
Greg
