Hello Guest it is November 01, 2026, 10:10:37 AM
Author Topic: Ellipse shaped becomes a polygon in Lazycam  (Read 19359 times)
Offline vadude
  •  18 18
  • WYSIWUG
« on: December 13, 2010, 10:14:55 AM »
My Lazycam Pro is behaving in an inconsistent way.I tried exporting an ellipse drawn with an autocad 2000 into LC Pro but it shows up as a 6 sided polygon. I drew another ellipse saved with a different name and it never showed up at all under LC.
    However,I am able to import all other shapes into LC with no problem. A search through the forum with "ellipse lazycam" as key words yielded similar postings/problem 2 years ago but members response blames it on the CAD program.
    Does anyone has a fix here?
No Pain No Gain
Re: Ellipse shaped becomes a polygon in Lazycam
« Reply #1 on: December 13, 2010, 02:55:26 PM »
Please upload your elipse dxf and be sure to name it something like "vadudeelipse12". Someone will be sure to look at it for you.
« Reply #2 on: December 13, 2010, 03:53:22 PM »
vadude,
See attached pic. The inside is an elipse drawn in ACAD2000 and saved as a ver 12 DXF. Just for kicks i also did some arcs which would make up an ellipse.
LC  imported both of them with no problems.
Offline vadude
  •  18 18
  • WYSIWUG
« Reply #3 on: December 13, 2010, 04:15:04 PM »
Saved the file as  "ACAD2000  ver 12 DXF" & it worked.Thanks to Budman68 & Rich for coming to my rescue.
No Pain No Gain
« Reply #4 on: December 13, 2010, 04:21:27 PM »
LC has imported other versions of DXF sucessfully, but as stated in the manual is is best to save as a version 12.
DXF is explained at a high level in one of the appendix.
« Last Edit: December 13, 2010, 04:43:19 PM by RICH »
Offline vadude
  •  18 18
  • WYSIWUG
« Reply #5 on: December 13, 2010, 04:30:27 PM »
Used Rich suggestion and it is working fine now
No Pain No Gain
« Reply #6 on: December 13, 2010, 05:21:16 PM »
Glad you got it sorted, Rich is the LazyCam God around here  :)
