Hello Guest it is November 01, 2026, 10:10:47 AM
Author Topic: "J Word Given For Arc" error  (Read 17395 times)
« on: December 11, 2010, 07:26:19 PM »
I am getting an error in Mach 3 that begins with the words "J Word Given For Arc" after generating code to cut a simple circle even in Lazy Cam.
I start with a circle, offset it, generate code and get errors. Squares are fine.
Anybody have any ideas.
Re: "J Word Given For Arc" error
« Reply #1 on: December 11, 2010, 07:39:41 PM »
Sounds like you're missing the J in the G2 or G3 line. you'll need to post the code.
« Reply #2 on: December 11, 2010, 08:35:46 PM »
It chokes at the first G2 code on line 60
Here it is:
N5 (File Name = Testes2 on Saturday, December 11, 2010)
N10 (Default Mill Post)
N15  G91.1
N20 M5 M9
N25 M6 T2(TOOL Change 1/2" Cutter)
N30 G43 H2
N35 G0  Z1.0000
N40 M3 S10000
N45  X6.2500  Y3.0001
N50  Z0.1000
N55 G1  Z-0.1250  F5.00
N60 G2  X9.7500  Y3.0000  I1.7500  J-0.0001  F50.00
N65  X6.2500  Y3.0001  I-1.7500  J0.0000
N70 G0  Z0.1000
N75 G1  Z-0.2500  F5.00
N80 G2  X9.7500  Y3.0000  I1.7500  J-0.0001  F50.00
N85  X6.2500  Y3.0001  I-1.7500  J0.0000
N90 G0  Z0.1000
N95 G1  Z-0.3750  F5.00
N100 G2  X9.7500  Y3.0000  I1.7500  J-0.0001  F50.00
N105  X6.2500  Y3.0001  I-1.7500  J0.0000
N110 G0  Z0.1000
N115 G1  Z-0.5000  F5.00
N120 G2  X9.7500  Y3.0000  I1.7500  J-0.0001  F50.00
N125  X6.2500  Y3.0001  I-1.7500  J0.0000
N130 G0  Z0.1000
N135 G1  Z-0.6250  F5.00
N140 G2  X9.7500  Y3.0000  I1.7500  J-0.0001  F50.00
N145  X6.2500  Y3.0001  I-1.7500  J0.0000
N150 G0  Z0.1000
N155 G1  Z-0.7500  F5.00
N160 G2  X9.7500  Y3.0000  I1.7500  J-0.0001  F50.00
N165  X6.2500  Y3.0001  I-1.7500  J0.0000
N170 G0  Z1.0000
N175  X3.7500  Y6.2500
N180  Z0.1000
N185 G1  Z-0.1250  F5.00
N190  Y8.7500   F50.00
N195  X2.5000
N200  X1.2500  Y8.7500
N205  Y6.2500
N210  X3.7500
N215 G0  Z0.1000
N220 G1  Z-0.2500  F5.00
N225  Y8.7500   F50.00
N230  X2.5000
N235  X1.2500  Y8.7500
N240  Y6.2500
N245  X3.7500
N250 G0  Z0.1000
N255 G1  Z-0.3750  F5.00
N260  Y8.7500   F50.00
N265  X2.5000
N270  X1.2500  Y8.7500
N275  Y6.2500
N280  X3.7500
N285 G0  Z0.1000
N290 G1  Z-0.5000  F5.00
N295  Y8.7500   F50.00
N300  X2.5000
N305  X1.2500  Y8.7500
N310  Y6.2500
N315  X3.7500
N320 G0  Z0.1000
N325 G1  Z-0.6250  F5.00
N330  Y8.7500   F50.00
« Reply #3 on: December 11, 2010, 08:38:38 PM »
Oh, and the entire error is: J word given for arc in xz planeLine 11
Thanks for having a look!!!!
« Reply #4 on: December 11, 2010, 09:50:48 PM »
You ran some other code that called G18 and put you in the XZ plane, and didn't return to the XY plane.
MDI G17, or better yet, put a G17 at the start of your code, and it'll run fine.
N5 G17 (File Name = Testes2 on Saturday, December 11, 2010)
N15  G91.1
N20 M5 M9
N30 G43 H2
N35 G0  Z1.0000
N40 M3 S10000
N45  X6.2500  Y3.0001
N50  Z0.1000
N70 G0  Z0.1000
N90 G0  Z0.1000
N110 G0  Z0.1000
N130 G0  Z0.1000
N150 G0  Z0.1000
N170 G0  Z1.0000
N180  Z0.1000
N190  Y8.7500   F50.00
N195  X2.5000
N205  Y6.2500
N210  X3.7500
N215 G0  Z0.1000
N225  Y8.7500   F50.00
N230  X2.5000
N240  Y6.2500
N245  X3.7500
N250 G0  Z0.1000
N260  Y8.7500   F50.00
N265  X2.5000
N275  Y6.2500
N280  X3.7500
N285 G0  Z0.1000
N295  Y8.7500   F50.00
N300  X2.5000
N310  Y6.2500
N315  X3.7500
N320 G0  Z0.1000
N330  Y8.7500   F50.00
« Reply #5 on: December 11, 2010, 10:35:34 PM »
Thanks Gerry,
That does seem to make it run. That may have to do with the fact that I am using SolidWorks to make the DXF and selecting the top plane. Perhaps the front plane would work better.
Any idea why it's cutting a gigantic circle? It was supposed to cut a 4" circle from the inside using a 1/2" bit.
Thanks again for your time. I am getting a V90 Fireball next week and am trying to figure out how to run simple parts.
