Hello Guest it is October 22, 2026, 04:31:51 PM
Author Topic: exact stop vs cv mode  (Read 14836 times)
« on: December 05, 2010, 05:54:14 AM »
Hi, I'm new in the forum and I new in the cnc to, I have a bridgeport cnc serie 1 boss w/ mach 3 and I'm learning how to use. yesterday when I star the machine i saw in abnormal condition in yellow, exact stop vs cv mode and I d'ont know how to fix that, I need help thanks.
Re: exact stop vs cv mode
« Reply #1 on: December 05, 2010, 06:13:34 AM »
Check your config and will you will see that that exact stop is checked. It is just alerting you that you you have a choice. Double click the button and answer yes or no as to
the mode you want. The button will then turn green.
« Reply #2 on: December 05, 2010, 10:45:55 AM »
thanks Rich for answer=2C in what part the confi I have to go to find the e=xact stop=2C because I saw in general configuration and i c'ant found anyth=ing. thank you again Rich.
« Reply #3 on: December 05, 2010, 05:22:57 PM »
see pic
« Reply #4 on: December 06, 2010, 06:40:03 PM »
Hi rich I can fixed the problem thank you very much master ;)
