Hello
Guest
it is
September 27, 2026, 02:11:36 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach Screens
My First Screen
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: My First Screen (Read 40464 times)
hacker77
34
Re: My First Screen
Reply #10 on:
December 01, 2010, 09:33:32 PM »
Here is something made up in a hurry. Just to practice using screen 4. I can't get the "dros" to move on screen or with my keyboard. Like I said before every other screen I load including benny's the "dros" start counting up when I load it in screen 4. Oh what is a "SKIN"? And somehow I lost the actual screen I was working on in Realdraw. Anyway another day for that. Btw could someone give a quick rundown of how benny made the button go from red to green in the 45sec LED video. I know he's explaining it ,but is that a red jpeg bitmap that he drew in realdraw and screen 4 changes it to green ? Thanks again guys for all your help. Rich
Logged
ger21
6,295
Re: My First Screen
Reply #11 on:
December 01, 2010, 09:39:28 PM »
There's a checkbox to "skin" a DRO. The skin is a semitransparent image to make the DRO look like it's under glass (or something).
Check the skinned box, then select an image, and when you close the dialog, the DRO will stat counting.
Here's more info on what's in the video.
http://www.machsupport.com/forum/index.php/topic,10761.0.html
Logged
hacker77
34
Re: My First Screen
Reply #12 on:
December 01, 2010, 10:13:23 PM »
Thanks believe it or not it worked!!!!!!!!! Rich
Logged
Klaus1311
531
Re: My First Screen
Reply #13 on:
December 02, 2010, 11:12:38 AM »
Hi Hacker77
on my website you can download a tutorial and a video, which gives you a rough idea how to work with MachScreen. The video is zipped and has a size of about 28MB, this may take a while to download.
The download path is:
Projects -> Mach3 Screendesigner ->Tuturial
Projects -> Mach3 Screendesigner ->Video
Klaus
Logged
The brain isn't a soap, it doesn't shrink when used.
Pythagoras
93
a² + b² = c²
Re: My First Screen
Reply #14 on:
December 02, 2010, 04:31:48 PM »
Thanks Klaus for your input.
The actual links are....
The Software
http://www.kd-dietz.de/download/eng/MachScreenV1.44.5a.exe
The tutorial
http://www.kd-dietz.de/images/eng/machscreen/praesentation/praesentation.htm
The Video
http://www.kd-dietz.de/download/Video/MachScreen.zip
The web site
Last Edit: December 02, 2010, 04:33:36 PM by Pythagoras
Logged
The Pythagorean theorem: The sum of the areas of the two squares on the legs (a and b) equals the area of the square on the hypotenuse (c). a² + b² = c².
budman68
2,352
Re: My First Screen
Reply #15 on:
December 02, 2010, 05:02:01 PM »
Klaus,
Thanks for the video, for some reason I have a habit of making things seem a LOT harder than they really are. Your video helped a lot and I'll give this screen designer some more use for sure.
Logged
Dave->
hacker77
34
Re: My First Screen
Reply #16 on:
December 05, 2010, 09:35:20 PM »
Benny on one of your screen sets in the scale axis "dro" you have +1.0, how do you put that value in without all the zero's on the end? On other screen's people just left it be .WhenI type in +1.0 all the zero's come back. Any info would be great. Thanks Richard
Logged
ger21
6,295
Re: My First Screen
Reply #17 on:
December 06, 2010, 10:39:50 AM »
Change the format in the screen designer. Don't have it in front of me, but it's something like f%+0.1
In Mach Screen you can just specify the decimal places and it does the format for you.
Logged
hacker77
34
Re: My First Screen
Reply #18 on:
December 06, 2010, 08:02:54 PM »
Gerry that works great I'm sitting here playing with MachScreen and trying to learn it. I'm liking it more and more. Thanks for all your help.
Logged
hacker77
34
Re: My First Screen
Reply #19 on:
December 06, 2010, 08:12:55 PM »
What oem code would you have to use for a vacuum table button or a dust extractor button? Or does those have to be done with scripts?
Logged
Print
Pages:
1
2
3
Go Up
« previous
next »
